Acura TLX 2.4-liter 4-cylinder Engine
TLXFan
With its 201-hp, 2.4-liter DOHC i-VTEC 4-cylinder engine, the TLX triumphantly combines high performance, light weight and fuel efficiency.
  • With the automatic transmission it has an EPA Economy Rating2 of 22 miles per gallon in the city, 31 on the highway and 26 combined.
  • The TSX SE with 6-speed manual transmission has an EPA Fuel Economy Rating2 of 21 miles per gallon in the city, 29 on the highway and 24 combined.
  • Intelligent Variable Timing and lift Control (i-VTEC) increases horsepower by advancing valve timing relative to engine rpm. High-rpm airflow is enhanced by opening intake valves longer and deeper at approximately 4500 rpm.
  • The all-aluminum engine improves front-to-rear weight distribution to improve handling and agility.
  • The Drive-by-Wire? Throttle system enables a smooth, powerful response with just the right throttle sensitivity in every driving situation.
  • A high-flow exhaust system and Programmed Fuel Injection (PGM-FI) ensure precise and efficient fuel use.
  • Dual balance shafts turn in opposite directions at twice the engine speed to reduce vibration.
